So been out felling for the last 2 weeks clearing a large site of about 50 large ash, oak and alder and was explaining the mechanics/ applications of a Dutchman/soft Dutchman cut to a colleague of mine as there were a few tall skinny ones that would have been ideal candidates to demo it but they werent marked to come out. Showed him the cut on a high stump but its hard to describe how it works without showing.
Just curious as to how many of you have ever had to use one in anger and what percentage are successful as i know it can be a bit hit and miss with these cuts (holding wood quality, species, frozen, lie of the land etc etc)
Any pictures or videos would be interesting to see.
Cheers guys and gals:thumbup:
  • Replies 30
There are a few good videos on youtube showing it. I have had quite a bit of success with it but was just wondering how many of you have used it and in what situations?
The domino fell looks like a lark...:001_rolleyes:
Ty
It's fine if you have a 20t pull skyline carriage. Otherwise its a PITA.
As for Dutchmen cuts tried them. They're OK but i'd never have the stones to use them how they do in the states. House 32"DBH Pine using a dutchmen to throw them away from the house. Not for me.
As far as I can tell they don't do anything a tapering hinge and a wedge doesn't do better. I have about 100 trees to fell tomorrow (and every day for the next week) and they need to be swung away from a loch, so I'll have a go.
Valid point. I think its one of those cuts that is intended for speed in a logging setting, for example if you get paid by the tree you dont want to be having to wedge over every tree if you can avoid it. As a practice and experimental cut its good to try out if you have the room and no obstacles to hit. I have to say that the success i have had has been with mainly spruce that can only be felled one way and have a slight side lean to them away from the target area and had to try and avoid the unmarked trees/ younger trees etc growing near by.
Good luck experimenting with it and let us know how you get on.
dont forget the camera for a few examples :thumbup:
Put a vid up years back its
Grainy long and boring but the swing Dutchman we used worked well in its job that day and put the tree with a heavy lean were I wanted with out the aid of a winch or line that tbh with the lean the tree had probably would of only been capable of doing the same job but with more hassle.
I like using a normal dutch mans to get a stick to jump a few feet off a stump like say felling high over a fence and to avoid hitting it.:) .. Never tried the soft dutch mans though.
