Niftysteve fitted this burner to my mums new place. The hobbit, 4kw, biggest stove available to fit the gap already there. That will need small logs.
If woodburners are about efficiency, what would be the point in having a big burner in a small room???:confused1:
[ATTACH]140633[/ATTACH]
No point at all but they are still a ball ache to cut. We have a 5kw in the front room and powered duct to other rooms heats the entire house unless its bitter then the central heating helps out. I find 6 in logs the best as you can get 3 or four in and still get the next ones in.
  • Replies 37
We have found most processors hate cutting small logs, I think it is a waste of good timber too, more cuttin means it ends up as sawdust. So should be a more expensive product. All our logs are around 8-10", seem to fit most stoves, even smaller ones, and have not had any complaints, we cut longer lengths to order off covered dry stacks 15-18 ".
6" logs are for wendy houses :) and I cant be bothered with them...
But it is soo frustrating when the damn things don't fit. Especially when still in yer PJ's trying to get fire going on a cold day. The last thing you want to do is go outside in the frost/snow and find a smaller bit or chop a bit off. I am more organised though now after three years.
Our Rayburn is 10" by 12" so the smaller bits get stacked one way and the longer lengths go the other and if they a bit too long they get stacked diagonally otherwise they get put to one side to be chopped up.
We call them 'granny logs'. Currently I don't charge any extra, but I will do soon. They take longer to process, there is more waste and there are less air gaps meaning they get more logs for their money. Basically they are a bloody pita!!
We have always charged 10% extra for anything shorter than our standard 10" log. More waste, more time, why should I put the extra time and losses in and be expected to absorb the cost?
I work along side the local stove shop and the smallest stove they sell has a 4" x 6" opening to load logs....
I provide them with 'baby logs' £8 per bag for a 25kg type bag and refuse to sell them in bulk as it's a lot more wood. I also stack every bag I sell so it's a bit more stacking...but a useful way to make profit out of the short junk/ends etc :)
HI MARC your right there mate 6":001_rolleyes:thanks jon :thumbup:
