3 hours ago, monkeybusiness said:
Rubber tracks only stretch when the internal steel cords are broken (and the tracks are subsequently goosed).
Tracks coming off regularly are either too loose or idler bearings have failed.
Or the grease tensioner has a leaky seal and is bleeding pressure.
57 minutes ago, Malus said:
I wonder if there's a difference in idler/roller design between brands that's better or worse. The little Kubotas are usually pretty good until the tracks get a bit stretchy. Have had issues with the Kubota u48 though, that used to throw off brand new tracks with no noticeable wear on the idler. Also had issues with the check valve on the track tensioner on a u48 so it wouldn't let grease in after putting the track back on.. may have lost a grease gun or two in a similar fashion to you 😂
I'm not the best at taking photos but here are a few from this job
Is that a dihatsu 4 track?
  Very nice work!
Been playing with this setup on a few jobs recently, (I've hired in the bigger excavator so don't shoot me down for the lack of guarding.) Mounting the grapple on the extension jib gives so much more dexterity and reach and add in the fun you can gain with the GMT total tree control it really is a fast unit to clear medium trees.
Being able to drop the GMT and quickly load chip with the clamshell is a massive bonus.
  • Like 10
Well I'm really impressed with these steel tracks. Should have made the switch (or at least bought a set for certain jobs) when I first got the machine. Way better traction. Better all round for rural type jobs. What's particularly impressed me is how good they are at tracking in. I've used them on crushed concrete and also dirt. Technically they are the same footprint so the same ground presure, but they really put it down. Make a very neat job. I always say that you can't use a mini digger for tracking in- they are designed for low ground pressure after all. Well you can with steel tracks!
These are double grouser so probably the optimum for my kind of work. I'm sure I will be equally impressed when I try them with some bolt on flotation bars for bog work.
£1600 well spent.
  • 1 month later...
Well we didn't go looking for this machine but when it came up for sale we had to have her. Takeuchi tb1140, such a stable machine and it just plays with all our attachments without any problems. Hopefully get the guarding sorted in the next few weeks.
  • Like 14
  • 1 month later...
Fitted a boom offset circuit diverter valve and extra aux circuit to my Kubota kx61-3 on the weekend with a view to using various attachments on the tilt hitch. Would like a rotating grapple but Christ they're not cheap!
Does anyone use a tree shear on a small digger, i.e. 2.5-3t? How do you get on with it and what jobs do you end up doing with it? Was thinking it could be handy for coppicing hedges that are too gnarly or overgrown to lay. Won't compete with a big machine though so maybe too much of a niche.
  • 1 month later...
10 years on from me starting this thread and my Arbdigger life has come to an end.  Had to face facts that my back can’t take the bouncing about and sitting for hours.  Luckily I’ve a good friend who has 1 with lots of attachments who loves sitting on his.
  • Sad 3
