On 23/09/2020 at 20:03, Gray git said:
Could be interesting for the boys using bigger 360 to load wagons with woodchip
You'd fill a bulker in 5 mins! Can't imagine anyone outside a power station has this much chip to shift.
  • 4 weeks later...
the additional pump on the 030-4 hi spec is elctronically controlled, there is a knob on top of the dash to control the flow. You can also program the flow using dash.
It may not be enough to run your hedge but I would think its possible to rob the flow going to the tracks electrinically so you get more flow to aux.
I can track and use the engcon on mine at the same time no problem.
At the end of the day the flow is there you just need to control where it goes.
I'll dig out the manual pages as you may not be on max flow for the pair of aux lines, may also need to flip the lever to drain to tank.
Edited by donnk
