Show us your Arb Diggers please.
Stephen Blair
LGP - does that set up require an additional hyd oil tank, pump and donkey engine or does it run fine with the machines standard oil flow?
forgive me if that's a daft question
Certainly not a daft question, and if money was no object plus I did a huge percentage of mulching then a complete separate powerpack on the machine is the way to go.
Ideally 100hp with all the pumps and cooling to match would really make it fly!
This is about as good as it can get on this machine utilising the standard hydraulics, and in Rhodies, which it does a lot of, it goes very well.
Eddie.
Eddie, I forgot to mention that we finally sourced a power pack solution co. Ranging from 45 to 150hp, kubuto engines feature plus an iveco - think we'll avoid that one! 100L/min 280 bar 75hp circa £15k...
You'll have to pm me a link if at all possible.
Thanks
Eddie.
Just dealing with a couple from the storms on the way out from a site we've been on and off for a couple of years.
Not really my thing, but no issues for the Kubota and winch, plus we managed to get everything back tidy on the verges.
Eddie.
Can anyone offer me some pointers of 'arb diggers'? I am looking at buying something compact for general landscaping but also to assist with shifting logs around the yard etc.
I'd go for something in the 1.5-2t range so I can trailer it. i'd like to fit a grab and rotor for ease of use when moving logs. Budget not huge so I would be looking at second hand.
How easy is it to fit a grab and rotor? Most diggers I am looking at are pipe for a breaker but I assume I need a second hydraulic service to power either the rotor/grab.
I quite like the Takeuchi TB16 and they seem to be in my price range.
Any tips?
Any tips?
Its easy enough to do, just make sure that the breaker circuit is double acting rather than single acting like most. You can T into the bucket ram since you will not need to use it with the grab & rotator
