Metal shuttering
Daniel Jiggins
Car or super single tyres, filled with subsoil or dirty gravel, staggered joints and raked back at an angle, if needed, but prob not, (vertically darned with heavy section re-bar, if paranoid).
Easy to place by hand, rounded and soft in appearance, everlasting, and vegitation can either be planted in the chinks, or will naturally grow over.
marcus
what's on top of the bank in term of loads
and it look like there is a differance in water leavels on both sides of the fence due to the fence stopping all the branches etc i would remove the obstructions so this dose not happen again,
and if you look at the posts the bank has failed were they were driven in and it will most lightly have been the process of putting up the fence helped it fail, along with the water trying to get around the blockage,
i would back fill with large stones and cap with soil to blend it in
See if there are any ideas here.
Pavingexpert - AJ McCormack and Son - Hard Landscape Features - Terracing
Something I saw yesterday... concrete hexagons ~12"x12" stood up[right, the tops cut square, the bottoms with three feet. Each foot stands in the top of a cylinder below. The end result is a honeycomb formed of rows of cylinders atop each other but offset so they interlink.
What I saw yesterday hadn't got the pots filled but you could easily do so with spoil.
Sorry for the vague description; I'm sure someone will know what I mean and what they're called.
The principle is very similar to Difflock's tightwad suggestion! :001_tongue: (I'm only jealous you thought of it first).
