  • Replies 22
Popular Days
I could get 2 of those in and put one on top of the other then James!
I reckon we need at least 25m of vertical reach for cut and chuck.
The tree is so compromised rigging is not an option.
Nah just use the 18meter and take a ladder up in the basket with you and a pole chainsaw :thumbup1:
Access is reasonably good.
I know the Teupens are expensive, has anyone had experience of working with Genies that size?
Genies are good hoists used a lot of diffrent ones from 40ft to 70ft, but they weigh a lot more than most, about 11 ton for one with the reach you are talking about.
Mark,
Try CWPlant in Ashford - Powered Access
Or I met these guys at the Kent County show and they had a fair big tracked machine there - Cherry Picker Hire Kent, Access Platform Hire London, Essex - who are in rochester.
If you need an operator for the day and get stuck then give me a call - I have IPAF ticket for Cat 1b Static Boom & Cat 3b Mobile Boom plus NPTC up to cs39 etc.
James
forget the genie as they cut out and go into a go slow mode if not level and a 26m would be at least 18t. I use a 23m tracked hinowa 'spelling not sure' from pwm platforms but a bit far from you I think.
Thanks fellas, your input is appreciated.
I'll bare that in mind James, thank you.
I've worked with a lot of MEWPS in a past career, telecoms, up to 60m, but I'm a baby with them in the tree game.
