New sawmill coming next month - need to sort out towing issues
Big J
Have you got some quotes for haulage?
The amount of money you're thinking of spending on a tow vehicle would go a long way in paying someone else to move it, and you wont have the headache of running another vehicle.
That is one train of thought that has crossed my mind certainly. There are several ag-spec Unimogs that I know of locally, so legal issues regarding the axles are avoided.
Perhaps the best conclusion would be to see how the mobile work picks up with this mill and then consider a suitable tow vehicle.
  • Replies 87
It's mainly as so much has to come off the length to make it legal here - we're talking 3m. It would have meant completely redesigning the sawmill, meaning a huge increase in cost and a compromise of the mill itself. I don't have a problem with driving a larger vehicle - I wouldn't want to tow something of that size with the Navara, and the extra width of a larger tow vehicle would protect the head rig.
Well the way I see that is, its a fold 1m or 3m makes no difference and if you want to tow it on the UK roads you are going to have to swap the axle anyhow, its not much of a re design because there isn't much to it, its a ladder frame on axles and a headrig.
Having is shorter to tow will make it a different beast in many ways, it will be a lot less prone to wag, it will be easier to store and the obvious manoeuvrability
If I were the manufacturer I would use this opportunity to make a euro compliant model, export sales and all that.
You mean this one:
Chevrolete GMC vandura pickup 5th wheel | eBay
So what is the law regarding towing a fifth wheel trailer?
Yes I came across it last weekend although cant see the fifth wheel I assume it must be seperate. No idea on the law on fifth wheel towing but I know someone who was going to produce trailers to take advantage of the 8250kg with out o licence. That gmc looked wide with enough power sensible fuel consumption low miles and not knackered and about 20k cheaper than a mog.
see link,
first one that came up,
searched for "UK 5th wheel towing restrictions"
I had reaserched this topic a few years ago in respect of moving a 4 tonne excavator, but it turned out to be simpler to spec a 7.5tonne beavertail.
5th wheel confusion UKCampsite.co.uk Caravan Towcars and Towing Advice Forum Messages
re brakes, same search question, 2nd or 3rd search topic.
With specific reference to American sourced kit!!
http://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_200827.pdf
Caravan forum is FOS, so much wrong I dont even know where to start.
Second link is very interesting though, still limited to a 7 metre trailer on a 5th wheel setup if the towing vehicle is 3500kg or smaller.
here is a copy of the latest info from DOT on agricultural tractors and trailers, it might clear up a few misconceptions.:-
This information sh
eet
provides an overview
of the safety requirements for agricultural tractors used
on the public road and
covers
the
main
points that are likely to arise
but for the definitive
requirements, the regulations themselves
or a knowled
geable trade association
such as NFU
AEA
or BAGMA
should be consulted. Details of how to obtain the regulations
are
in
section
4
below
1.
Overview
An
Agricultural
tractor
i
n
road vehicle
legislation i
s
a vehicle that is designed for, and
used solely
for
agricultural purposes
. If it is a multi
purpose
tractor
, used partially for Agricultural purposes,
and partially for general haulage, it is no longer an Agricultural
tractor
and it must meet the
stan
dards applying to standard road
going
haulage vehicl
es
Haulage vehicles are subject to
„plating‟ and annual testing with VOSA, Operators licence, use of
tachographs,
and use of white
diesel only.
is defined more precisely by HMRC on their website and is interpreted
exactly the same w
ay by the D
epartment for Transport
The following link gives guidance.
HM Revenue & Customs
geLabel=pageExcise_ShowContent&id=HMCE_CL_000164&propertyType=document#P312_3128
3
Many
Agricultural
tractors (when new)
are
subject to
type approval
(the governm
ent inspection of a
vehicle before it is registered).
Other categories are exempt.
(Consult the manufacturer for details).
All
tractor
s
still need
to comply with the standards
for road use
that ap
ply to all vehicles in Britain.
2.
Maximum weight, length a
nd width
The maximum
(gross or fully laden)
weight
of an
agricultural
tractor
is 24,390 kg.
The maximum
weight of
a
n
agricultural
combination
(tractor plus trailer)
is
also
24,390 kg
The maximum
length
of a
n agricultural
tractor
is 12m.
This is unlik
ely to be exceeded so it is more
useful
to list the maximum length of trailer that is allowed. This is normally 12m.
In the case of a
Composite trailer
semi
trailer
and
converter dolly
) the maximum length is 14.04m. In the case of
an
Agricultural traile
d appliance
in other words towed equipment
(with gross weight less than
double the unladen weight) the maximum length is 15m.
The maximum
width
of a tractor (or trailer)
is 2.55m. Certain essential parts such as lights and
mirrors can be ignored when mea
surement of width takes place.
Under special circumstances Agricultural vehicles
wider
than 2.55m are permitted to use public
roads. The Road Vehicles (Authorisation of Special Types) (General) Order 2003 (known as STGO)
permits the road use of Agricultur
al vehicles that are up to 4.3 metres in width, subject to terms and
conditions. The key ones are as follows:
Wid
th
between 2.55m and 3m:
speed must not exceed 20mph.
W
idth
between 3m and 3.5m:
maximum
s
peed
20mph
as above, plus if the journey
is ove
r 5 miles or the speed limit in the road is 40mph or lower, (or both), the
operator
must notify the Police in advance of the journey.
W
idth
between
3.5
m and 4.3m: the P
olice must be notified, the maximum speed is
limited to
12 mph and the vehicle(s)
must
be accompanied by an attendant, who may
ride in a different vehicle but must ensure no danger is caused to the
vehicle
or other
Information sheet
AGRICULTURAL
TRA
CTORS
a brief guide
road users. The police, following notification, may place restrictions on the use of the
vehicle in the interests of road safet
y or to avoid undue traffic congestion.
For full details
on the requirements applicable to agricultural vehicles wider than
2.55m, the
legislation can be found at:
3
Braking requirements
The braking requirements depend on the speed at which the tractor travels
, and its age
Agricultural
tr
actor
used at speeds
not exceeding
20mph,
or
which was manufactured before
1986
braking efficiency of at least 25% is required. In the event of failure of any part, the brakes
must still be capable of bring the vehicle to rest in a reasonable distance. A
mechanical parking
brake is required, which can hold the vehicle stationary on a gradient of at least 16%.
Agricultural
tractor
manufactured since 1986
and
used at speeds exceeding 20 mph
braking
in line with ECE Regulation 13 or EEC Directive 71/320/E
EC.
er to check
whether the tractor
complied when it was new. Most tractors do not comply with these requirements
so should
only
be used at speeds up to and not exceeding 20mph.
4.
Amber w
arning beacon
Tractors which are incapable b
y design of exceeding 25mph,
may
be fitted with a
flashing or
rotating
amber warning beacon
, which may be used where necessary to warn other traffic.
If such a
tractor is used on an unrestricted (i.e. 70mph national speed limit) dua
l carriageway,
other
th
an crossing it by the quickest manner practicable,
an amber beacon
must
be fitted and must be
kept on.
Any amber warning beacon fitted, whether voluntarily fitted or required by regulation, must be fitted
in compliance with the requirements of Schedule 16
of RVLR. Schedule 16 requires the centre of
the lamp to be not less than 1200 mm above the ground, and the light to be visible from at least one
beacon (but not necessarily the same beacon) from any point at a reasonable distance from the
vehicle (i.e. t
hrough
a full
360
5. Other lighting
Lights are not required on a tractor which is only used
on the road
during the hours of daylight
, in
conditions of good visibility. If this is the case, the driver is required to use hand signals to indicate
chang
es of direction a
nd when he is slowing down.
Otherwise, lighting is required
as in the table
, based on the maximum speed of the
tractor
and also
when it was first used.
Maximum Speed
Types of lamp required to be fitted
Any speed
Front position lamp
side
light)
Rear position lamp
tail light
Rear retro
reflector
More than 15 mph
As above, and also
Dipped
beam headlamp
Direction indicator
Hazard warning flashers (4 way direction indicators)
More than 25 mph
All of the above, and also
Main
beam hea
dlamp
Rear fog lamp
Stop lamp
not required on agricultural vehicles first used before 1 April 1986
Direction indicators are not required on agricultural vehicles
(e.g. ATVs)
with unladen weight less than 255kg.
6. Maintenance of agricultural
tractors in a safe condition: Farm vehicle health check scheme
The manufacturers of agricultural tractors must build vehicles which comply with the rules when
they are new, but it is the
owner’s responsibility
to ensure that the tractor is properly servi
ced and
maintained so that it remains in a
safe condition
. This is legally required under various Health and
Safety laws.
To help farmers and contractors achieve this, industry partners have prepared guidance in the form
of a Code of Practice, setting out
a Farm Vehicle Health Check scheme. This is available on
BAGMA‟s website and sets out what is required in plain language:
http://www.bagma.com/newsroom/bagma
news.html
7
T
he Road Vehicle (C
onstruction and Use) Regulations 1986
, and the Road Vehicles
Lighting Regulations 1989
These are the two main sets of regulations governing vehicle construction standards.
T
he
first
set of
regulations
Construction and Use: or C
&U)
are not available on
the internet
and
both
sets
have
been amended
several
times
, particularly C&U,
which
mak
es
it
difficult
to piece together the latest
version
of the
se
regulations. However these regulations are available in a consolidated format in
most city reference libra
ries, from companies who publish law. One example is 'Sweet and Maxwell'
who publish the “The Encyclopaedia of Road Traffic Law and Practice”. This publication is
continuall
y updated and Volume 4 contains
full version
s
of the
above
mentioned regulations in
consolidated format.
Other p
ossible suppliers include InterRegs, who charge
around
£16
0
for a fully
consolidated version of the Construction and Use
R
egulations. This can be obtained from:
SELECTREGS.COM from InterRegs
SI1078
8
Other matters
driving licence
It is important to ensure the correct
driving licence
entitlement is held.
More information is
here:
http://www.direct.gov.uk/en/Motoring/DriverLicensing/WhatCanYouDriveAndYourObligations
Agricultural tractors are class F, if you have this entitlement you can
also
use your tractor to
draw
any (legal)
Agricultural
trailer although there are some restrictions for young drivers.
The standard car licence (B) gives entitlement to class F automatically. However it is advisable to
undergo some training and practice off the public road, before driving a tractor for the
first time on
the public road.
9
Important
disclaimer
about this Information Sheet
The views expressed in this Information Sheet are based on the Department‟s current understanding of what the law
means and are not definitive. Only the courts may inter
pret legislation definitively. If you are in any doubt about your
legal obligations, you should take independent legal advice as this Information Sheet is not a substitute for such
independent legal advice.
