What do you do to cope?
I'm drinking 4+ liters of water during the working day, slapping the suntan cream on & struggling. Due to corporate policy I have to wear type C clown trousers, so any helpful tips on surviving are welcome
  • Replies 49
Am the same Pete. Having to struggle through. Are you wearing cotton tshirts? find the tech fabrics can help. Plenty of breaks helps, can make jobs longer but sickness through heat stroke etc will also do this. If it is possible rotating climbers over a couple of days so you can wear type a, have an easier day is an idea.
stay indoors!! Wearing type c might compromise hs policy, due to risk of heat fatigue.
If forced to work on hot days, if possible start at 5am and finish at lunch before max daytime temp around 3pm.:thumbup1:
Starting up your saws at 5am will attract some compliments!
Freeze a couple of bottles of water, thaws during the day giving lovely chilled water
I also carry a 40l drum with a tap on it, luverly to dunk your head under cold running water.
Type A's for sure in this weather. Straight off into shorts when all saw work is done. May not look proffessional, but neither does a load of heat struck, sweaty buffoons.
And of course, more water than's in the atlantic:cool:
trees, waves and cakes!!:-)
