Some of you may have seen my post regarding a small woodland I have purchased the timber from for firewood. Its 90% Norway spruce of about 20 years old and most of it is in the 6-10" range. I am felling and stripping manually with chainsaws , Im I no hurry to do it as it as much a hobby as anything. I wish to cut the trees into 16ft lengths and take them about 200m across a field to the road side using my tractor, an 885xl International 4WD for collection by artic timber skelly.
My question is should I use the front end loader and make up some kind of a grab and carry the timber out or would I be better to skid them out behind the tractor using a chain and maybe some kind of attachment to lift the butts clear of the ground? I'll probably make a grab for the loader anyway to help with stacking the logs for collection.
I saw this on youtube and thought it was a good idea. I want to be able to carry several lengths at a time as there is 12000 to come out. [ame=http://www.youtube.com/watch?v=WolPsDoUaCE]farm tractor with skidding lever - YouTube[/ame]
  • Replies 51
Skidding makes an awful mess, and with the amount you have you would be better hiring in a forwarder to extract. Would you be stacking it at roadside, because I wouldn't imagine a lorry picking up 12000 lengths that are not stacked to 2 meters high. Where abouts are you?
12000 tons!
That's about 450 artics.
Presuming a (very very generous) yield of 100t/acre, you're talking of clear-felling 120 acres.
There's no way one person with one tractor is going to make that happen, so shall we assume it was a typo? (Especially as you said you got a Small woodland...).
As mentioned above, skidding it will rip the ground up quicker and leave product covered in mud and stone.
Forwarding trailer would be ideal, but on a budget, some forks/grab on the front loader and a farm trailer would do. We've had to use forks and farm trailer for stuff that the forwarding trailer won't lift.
Just read your other post, as it is a clear fell job a farwarded hired in or get you own timber trailer is the best bet. Skidding timber is time consuming with chains/winch tongs on back of tractor are quicker if just line thinning.
I guess you mean 12,000 pieces not tons?
12000 tons!
Yes its 12,000 trees and not tons and the majority are no bigger than 8" in diameter. the whole site is about 5 acres. It hasnt been thinned or maintained. I thought skidding would be fine as I have access across a very broad front maybe 300m and not tied to a lane or track and can take a different route almost every time.
As its only for personal firewood I wish to keep the cost as low as possible. I have a small engineering workshop an could manufacture most types of grab or simple machine if there was something which would be useful.
I do wish to stack them in an adjoining yard for artic collection.
