the 070 is just about to be broke in mate at the mo the 076 gets hit had
that's some nice timber josh
Just checked - my 070 has the overspeed regulator on the notch nearest to the back end.
Alec
As this is a thread awash with milling expertise can I ask if anyone knows if big Swamp Cypress - Taxodium distychum - is of commercial use, presumably in a milled state?
This is a very early enquiry on behalf of someone who hasn't even seen the tree yet but has been told it's 4' thick: let's call it 3'!
Access I'm told is poor so even if it was worthwhile I guess a Lucas Mill would be needed unless the tree's smaller than claimed.
Thanks,
Jon
Never come across it, but Cypress | The Wood Database - Lumber Identification (Softwoods) says it should be worth the effort, maybe for cladding or decking?
If access is too bad for a Lucas mill it could be done with a combination of Alaskan mill to cut cants, followed by Ripsaw mill to break down into boards.
Alec
Thanks,
Jon
Supposed to be very water resistant and fine, dense timber.
Thanks,
Jon
it's great for outdoor furniture and doesn't need treating. definitely worth milling.
some lucas milling we did for a customer
joy
Sent from my GT-I8160 using Tapatalk 2
hi joy,is that the dedicated slabber or just the slabber attachment? cheers:thumbup1:
36" Alaskan mill with stihl 880. Cuts were fairly quick and smooth. Tree was about 2 foot wide. Mostly took of 2" thick boards through and through and a couple of 1" thick. Any bigger and we'd never have shifted them
