9 minutes ago, Tom BOP said:
Sometimes needs must. Had to get kit off site with in planning time constraints/working hours
Theres still space in the back of the jeep!
Nicely packed in though.. 16ft or longer?
16ft. Only took it about a mile to get off site and then split the load down and moved the machines individually. Although it was heavy it towed well. The access there is very tight and the site is very tight. I have to drop the trailer off to turn it round all very time consuming
Whats that green length of metal on the digger arm?
The green length of metal is my laser receiver bracket.  For me it works very well.  However do not think that you can dig to it as it is far to accurate/twitchy.  For example when digging footings.  Dig as per usual feeling your way but just before you track back have a quick dab to the bottom of the trench, thus preventing accumulative errors.  I find having the bucket flat the most accurate, it is possible to take a very shallow scrape at this point if necessary.  Obviously the dipper arm has to be vertical and it is surprisingly easy to achieve this.  I apply the same principle when leveling stone or top soil.  I would love to justify the expense of a DGPS or Gyro system produced by TopCon, Trimble or iDig.  We can all dream!!
  • Like 6
Just a bit on the heavy side, over for trailer but ok for the vehicle [emoji16]
Nice setup [emoji106]
How is the winch/crane attached to the trailer?
Hi Rough Hewn, the crane comes with a 300mm approx square plate on the base so I welded it to a 600mm square plate that is bolted through the side rail, front rail and goes down through the bed and picks up the main chassis rail with spaces between the bed and rail to keep it all nice and rigid.  Will try and find a pic if I can.
