  • 8 years later...
  On 24/12/2012 at 07:57, BenR said:
I used to find an o rig a PITA if i wanted to advance my line on the way up, if I didnt hit my top anchor with the throwline straight away. Used to just use a sling to the hitchclimber. Easier changeovers.
Expand
Hi Ben!
Potentially looking at giving this set up and my only concern at the moment is what you have mentioned in regards to advancing my line if I don't have a set TIP.
Quick question: where you using a termination knot or a spliced eye on the tail of your rope?
Can't imagine it being much more effort with advancing using a spliced end.
I still climb ddrt about as much as I climb srt.
Never used anything to extend the system away from me though. You're still using your arms to pull yourself up long ascents and it just doesn't make sense to me.
  • 4 weeks later...
Adding a short double eye cord makes advancing the anchor in the usual way, the top left hitch needs hooking up when in use. Prusiks are shown to represent friction hitches, climber’s choice.
Edit: I didn’t use the friction hitch tending Prusik that crosses over, just as easy to push it up, and made advancing TIP one step simpler.
Edited by Brocky
Forgot to add
Read more
