  • Replies 35
Have you considered making an elevator/conveyor?
Not as troublesome as you think.
Its a common industry, and a lot of stuff is cheap and standardized.
You can buy all the standard side channel sections off the shelf, rollers are simply hex bar, a bit of tube cut to length and a plastic bearing in each end.
Belt is most expensive, plenty people around to make one, motor and gearbox is what you need to find second hand...
  • 1 year later...
I don't know if they ship log elevators to UK or have a dealer. There was recommended prices (without VAT) on their Swedish site. Maybe those prices can give an indication..
Thanks. I'll go and brush up my Swedish!
If a Sek - 0.086 British Pounds
Logconveyor 5,0 m width 100mm 0,37 kW Motor, 2 Sections 6400:- £550
Logconveyor 7,5 m width 100mm 0,37 kW Motor, 3 Sections 7900:- £680
Logconveyor 5,0 m width 200mm 0,37 kW Motor, 2 Sections 9800:- £850
Logconveyor 7,5 m width 200mm 0,37 kW Motor, 3 Sections 11450:- £985
With hydraulic power source 150:- 13
Logconveyor 5,0 m width 100mm Hydraulic motor with quick couplings 7450:- £650
Logconveyor 5,0 m width 200mm Hydraulic motor with quick couplings 10600:- £910
Logcutter 700 4 kW Motor, 1800mm logtable,
sawblade 700mm 10150:- £875
I have bought them on ebay for £400-£600 different designs some work better than others. I would avoid the miniveyor builders rubble type stuff as its a bit slow and clogs up if you get some steam up. If you pay £200 for a less than suitable conveyor and get a year or two out of it you have had your moneys worth it saves your back and makes the job. 4metres is a bit short and 6 metres too long unless you are trying to make a huge stack.
