Beginners climbing guide, hints, tips and general climbing techniques
Thanks guys
Im using 11mm dynamic at moment for like 10 times and it looks kinda wear out all ready in some places.I've bought new 11.7mm Donaghy Cougar Red, Yellow, Black and bit worried about do any damage to it.That's why asking before takin it out.
So the normal double rope technic doesn't hurt the rope as much as I thought?What is actually rope life with doble line usage?When is the time to change it?
Thanks guys
Usually when it gets cut with your saw/silky and becomes too short.
Probably just me...
Thanks guys
Well theres your problem. 11mm Dynamic you say, as in rock climbing rope? Rope climbing ropes outer sheath is nylon whereas proper arborist rope is polyester. nylon has a lower melting point than polyester and isn't designed for use with friction hitches.
You'll be fine with the Cougar :thumbup1:
If your climbing on a blakes you might want to get a split tail to reduce wear on the end of your rope,cheaper to replace a split tail than cut lengths off the end of your rope in the long run.
Have you tried a prussik loop yet?
Agree - important to know how to tie the traditional 3 knot with Blake's for the climbing test, but prussik loop and 2 carabiners is much better than having to untie when advancing the anchor point.
Steve-that's why I bought cougar.Didnt have that kind of information when I was purchasing first rope :-( thanks for explanation.It really is pain.No just bounce /and it does bounce a lot/ but when I do Blake's hitch it have no friction at all or when I tight it harder it is hard to slide.But with cougar it should be solved as you said then.
Stihl-I'm using another piece of the thinner rope which one end is connect to my harness and other to my climbing rope by B-Hitch.
But bought that one recently I planning to try to
