Hi all,
I think chainsaw sharpening may be on the way out.
The reason........
The 12v sharpener that Robs selling for £50
Its just too easy, theres no fun winding the groundie up any more when he's sharpened the saw and it cuts worse than before he mutilated it...
After 10 mins play today, we'd got it up and running to my liking.
It took all of another 10 mins to sharpen a totally mullered chain off the 36" husky !!!!!
We were ringing up a quite naily Horse chestnut butt, so the sharpener got quite a good workout.
Can highly recommend these to anyone, a good £50 spent
  • Replies 26
Glad you're liking it!
I've started using it on my other saws now a lot more..... had a chain on Husky 346 that had 25% left in it. Hand sharpened and was cutting like a dull chain so used the precision grinder to get the teeth consistent and then used a 5/16" stone to do the depth guages all the same height. It doesn't give the depth guages a great shape but it's not bad and was very quick to do. Result - chain cutting perfectly again.
Got a bit of confession to make :blushing: as until recently I'd not been lining up the chain 'holders' correctly - I'd always had them below the rivets when they should be just above. This meant the chain was pulling up as it was sharpened. Now it stays firmly in position.
:001_smile:
I won't ever be using one of these, a round file in the right hands will bring even the worst chain back in well under 10 minuets, grab a new file and its even quicker.
I reckon the masters of the art of sharpening will carry on and they will pass it on to the next generation of pro's.
Don't knock it until you've tried it Dave!
I still enjoy hand filing but I just need a guide every third of fourth sharpen to get everything back right again.... not too proud to admit it and I've been sharpening 10 years.
You have to have a very good eye to get a chain spot on in terms of tooth length and shape so each tooth is taking the same bite - alas I have not got that eye! This guide gets it pretty much spot on and you don't have to think about it other than for the first tooth.
I got mine a couple of weeks back to rescue two 36" chains after hitting some concrete inside a log. Had to take back about 3mm to get to chrome and they've come up lovely:thumbup1: I did it in stages mind, so I didn't over heat the chain.
Hmmm, I'd be interested in taking you on in this - me with the grinder, you with a hand file. 47" bar, ripping chain, one tooth taken out by a nail having lost about 1/8", all the other teeth to be taken back to exactly the same length....
I reckon I can do it in under 10mins from the word go, I suspect you couldn't shift that much metal in the same time.
Alec
I just don't see the problem that this is here to fix, sharpening by hand is a dodle, it takes minuets, I was amazed when I first came on here and read about people who change the chain, because sharpening takes so long. I even timed how long it took to sharpen my 66 with 25" bar, it took 2minuets.
I've worked with dozens of cutters and sharpening has never been an issue.
