Can you explain the 2nd pic ie art pos and zigzag all on the same d ring and looks like a screw gate on the zigzag ??
Sent using Arbtalk Mobile App
Small Wellingtonia to come down, small garden and a bit of a drag but we got is boshed in the day and got rid of all the wood.
Forwarding in the soup. So so so wet the legs sink a long way.
At least your botex has legs ours are currently being welded back on
ImageUploadedByArbtalk1393878985.105298.jpg.3f6ffa4f5ac27fe6acdec2b576f41f04.jpg clearance job today, they are putting a third lane in for the roundabout so a blackthorn and young oak clear fell
Been there done that:001_tt2: only did one though.
Did you break the rams too; i did. If you need new rams order them your self as browns charge you a fortune for them to pick up the phone and phone Ewan at Wilsons.
Since i broke the first leg on a stump 18 months ago i don't use them that often anymore.
Wasn't me but yes sheared off both sides and bent the rams both sides, cheers for the advice, will let my manager know,
The rams are quite reasonable priced. If the cylinders are ok might be worth a quote on just getting the rods done. Try hopespare in Hemel Hempstead.
Other than that you just need to heat the legs up bend them straight and do the same for where the legs attach to the chassis. I think it was over a grand for the leg that i did.
