5 hours ago, Stere said:
Ok so whats with  the  high stumps?
Not sure but to be a member of the mile high stump club is not cool 🫣
Left high for a digger to pluck them out, duh. There was a lot more wrong with the job than that (only in my opinion of course) but that's what we were asked to do so we did it.
Nothing exciting, oak reduction previous cuts were awful.
Crap anchors, spanned two limbs.
Ash reduction, tight drop, plastic corrugated sheeting, AstroTurf and a green house.
Had been absolutely hammered in the past completely flat not to points. Did the best I could, not pretty but not worse.
Tpo'd complete waste of a tpo
Spare climber gave us a hand to chuck it into the tight drop area, I went over the stubs I left some as I was uncertain if I was going to leave it or take more.
On 08/04/2024 at 17:36, AHPP said:
Second job for my little mincer. Smashing thing. Loves conifer.
I've found with my Jo Beau that you get better mincing of the greenery and less blockage from it if you post narrow brush like that into the machine the wrong way round. You get a better mix of green and brown material being chipped together: with the branch the 'right' way round you chip all the brown, then all the green
Blocking isn't a problem with just the smallest smattering of vigilance. I only held that bit back for a slightly finer mince. It had the power to take it through unattended. The problem with tip first is that it means butt last. Heavy bits can bounce around on the drum and come back out of the hopper. This is my first attempt setting the anvil gap. The manual is sod all use so I'm learning as I go. Going to try a slightly larger gap for a greedier feed next time. Has your Jo Beau got a feed roller?
