These spot on on rough grass then for Ash dieback grenade etx then?
Like Mark I wanted one with a barrel or cylinder mounted 90 degrees to the rake so I can grab it with the grab
2 hours ago, Mark Bolam said:
Got it.
I’m thinking of getting this Klou one for my Worky Quad.
Same idea, just pick it up keeping the grab on.
I won’t be able to rotate, obviously.
How much are they mark? No price on website
13 minutes ago, AHPP said:
Presumably the round grab handle is so the rake follows the ground contours?
Yes the guy made it heavy ish so grabs it and let's go a little so weight of rake loose in the grab then rakes along. Awesome on digger woth rotator. Rake a big area I without moving
Thanks Swinny.
Could be worth a call, but I doubt the price will be that different with mods.
I thought the price wasn’t bad tbh, but your guy seems even keener.
I talked about this with @doobin before Christmas.
Time you’ve bought the steel and tines and done the fab you’re better off just hitting the ‘buy now’ button!
3 hours ago, bigtreedon said:
not the best photo but if u zoom in you will probably get a idea 20231205_114303.jpg.44ceff2e37d656333e463e2190e54a34.jpg
Don is there any truth in the rumour that the Vermeer will lift 5t with you stood on the back plate?
11 hours ago, Mark Bolam said:
Thanks Swinny.
That one from Dom Harrison looks a good design. Thats how id do it for the multione.
I’ve never bothered as I just use the one I made for the digger, and if the multione is on site then the forklift broom is brilliant for a final pass.
