1 minute ago, carlos said:
are you meant to fix through the troughs?
Two shops swore blind you can and the boss chose to go with it. I remain sceptical.
fair enough,ive not used the square section stuff, just the traditional half round profile.
Same. The trough is at least flat.
Logic suggests ridges would be better, however when you look at the seal Neoprene Tek screws achieve, it's a moot point. You can deform ridges if you're over enthusiastic with the impact driver.
Fixing through the troughs is the accepted way forward on box profile.
As Peter says, decent screws are important.
And I’ve been there on the ridges thing!
1 minute ago, Deafhead said:
Southern Sheetings website, all the info on there.
Hey that's where I started milking cows many years ago, the railway cutting was  landfill , now the Bluebell runs through it again.
