I agree , sometimes its just not required to take a saw up . If it looks like alot of tension in the branch may have been better to put vertical cuts in but twenty twenty hindsight and all that :001_smile:
  • Replies 23
Could you perhaps have taken the weight of branch using lowering kit, worn spikes for said branch, gotten further out on said branch to cut in smaller sections, used slings to choker to get foot hold, 2 anchor points for a better work position or simply reached out and slashed it off with a topper saw.
Seems strange for sycamore to hold like that? Especially that diameter and length ?
We have sycamore trees over here that would easily meet that length and weight. Nasty dirty trees IMHO :thumbdown:
easy-lift guy
In hindsight, I think a sling would have been the answer, without which I wouldn't even consider using a chainsaw - what's worse, the loss of 6ft of lanyard rope or an avoidable accident? But I'll definitely try the sling next time - they're so versatile.:thumbup1:
I think the use of slings would have made it safe to use the top handle, alternatively I would have taken the cut out further from the tree to remove the weight and then removed the stub. Ive experienced similar situations in wet weather, and I prefer where possible to postpone the work if the weather is or has been bad enough to make the tree slippery, schedule permitting of course
easy-lift guy
In the UK Sycamore is Acer pseudoplatanus, your side of the pond you call Platanus occidentalis sycamore.
i personally would think about what happened and try and work out a better way of doing it ..... although its a lesson to learn which didnt go horribly wrong if we are all honest enough to admit it we all have made errors of judgement ... if your not sure take your time and consider what you are doing .
