  • Replies 36
i can vouch that chassis cleaner does damage the engines which run on the rotary type (Bosch) injection pumps as fitted to many Chelsea tractors. the chassis cleaner reacts with the aluminium body of the pump causing it to becomes gritty and the grit then jams in the pump rotor which in turn sheers. it may take a couple of weeks to work but it does work.
Would be nice to give them the preverbial bloody nose, however I suspect it wont take long for them to realise what has happened, then they find out who owns the farm/tanks and you have a world of grief.
Better security or diesel elswhere for the coursing season. They dont play fair and tend to hold grudges.
costic soada is good , the only trouble is a farmer in this region found out if the wrong really wrong types have it away and have trouble it will bite you bad they did £ 500.000
worth of damage to his farm the next week , so a trip wire and plastic just eradicate them
