Mirror mirror on the wall.... who makes the best chainsaw file of them all?
I am truly saddened and surprised by the fact that 6 arbtalk members have chosen to exploit this initiative to get three free files with free shipping,
I'm not taking it personally morten as really I'm sure it's just down to time pressures and work more than anything else.
:001_smile:
  • Replies 112
Wen marking them in future rob why not dip the end of files in different colours of paint? Can't help with the grinding though.
Sent from my HTC Desire using Tapatalk 2
I think that's what I'll do for next time - do a paint dip - this time I found it easier to get a kit together in one hit and pack it so no chance of anything getting mixed up....
Didn't mention it before but that packing - man that was one big parcel for four tiddy files - the wife got quite excited, thought it was a pressie for her:blushing::lol:
Cmon lads, get those results in, I am a busy man and filed a couple of chains to get my results back what seems weeks ago!!
Me too couldnt thin k what Id ordered:confused1:
Yep same here!
I am starting to wonder if we should set off (yep probably in single file), roam the country in some sort of press gang to sit them down and make them sharpen their bloody saws!!!
I dont reckon Rob will get many more results in to be honest. Maybe he could PM the overall results to those that have returned theirs as a reward for their loyalty and damn good form!!!! :biggrin:
In return we promise not to publicly reveal ourselves
Ok - we have 13 results out of 18 which is not all that bad...
I've checked over them and they should be accurate but knowing me :001_rolleyes:
File test results
Just thought a simple points system would work the best so:
Best = 4 points
Pretty good = 3 points
Not bad = 2 points
Last = 1 point
The files on test were Save Edge – a new brand from the States (although does say made in Portugal on the files!), Vallorbe, Oregon, Stihl.
1st place – Save Edge with 38.5 points. Some people did not like it but this file is the most aggressive and removes the most material per stroke (see endurance test).
2nd Place tied – Vallorbe and Oregon with 32 points - smooth filing and consistent results
4th Place – Stihl with 27.5 points -a little disappointing from the market leaders although scored first by a couple of testers.
So which file was which?
Unmarked was – Save Edge files info found here and I'll be selling these soon as they did well. I like their raw aggressive material removal and they keep their edge Save Edge | Home of the sharpest files in the business.
Shiny tang was – Vallorbe – found here. A major supplier of files and they have always made Oregon files http://www.vallorbe.com/Standard.php?p=530&m=4&l=3#
Shiny end was – Oregon (made by Vallorbe) – found here OREGON brand Saw Chain Round Files for sharpening chainsaw chain
Black end was – Stihl – Files are made by Pferd and Vallorbe?? Neither/both? See further posts for more info on Stihl files.
Breakdown of results and testers comments
Best – Save Edge – 4 points
Pretty good – Vallorbe – 3 points
Ok – Stihl – 2 points
Last – Oregon – 1 point
Best – Save Edge, a clear No1 – 4 points - nice grippy file, takes off loads of metal
Pretty good - Stihl – 3 points - not as good as above
OK – Vallorbe – 2 points
Gotta say that the last two were pretty much the same and suspect they are from the same factory
It was a tough choice for top place mate.
Best – Oregon – 4 points - removed the most metal on each stroke
Pretty good – Vallorbe - 3 points - slightly less aggressive than the above but more consistent over time
Ok – Save Edge – 2 points - similar to shiny tang but began to skid a bit after several cutters
Last - Stihl – 1 point - took the least off on each stroke and tended to skid more than the others
Best – Oregon – 4 points - really good - smooth and efficient from the first strokey! easy fave straight off
Pretty Good – Stihl – 3 points - started off a bit chattery but settled well
Ok – Vallorbe – 2 points - just slow
Last – Save Edge – 1 point - chattery as hell - might settle down eventually - hated it
1st place – Oregon – 4 points - good smooth action and most polished/ smoothest result.
2nd place, Stihl and Save Edge – 2.5 points each. Not as smooth as shiny end, and a courser finnish to the tooth. ( i could not tell these apart)
4th place – Vallorbe -1 point - Coarse finish and the filing action nowhere as good or smooth as the others.
A file is a file and testing was a bit daunting. I took no note of marks, bunched em on bench and tooth by tooth mixed and matched, all the while ranking them in order and verifying as I went double checking, trying a file again.
What do you actually want from a file? Coarse and quick action or smooth minimal swarf?
Left it a while did test again as above bunched on bench and got same results. So am happy I’ve done it independently.
I use a husky combi guage with rollers on and currently use windsor files from a job lot I got off ebay a few years back. I’m a thrifty file user and make them last. Clean them after a days use rubbing them with chalk stone and brushing off, etc
1st – Save Edge – 4 points
2nd – Oregon – 3 points
3rd – Vallorbe – 2 points
4th – Stihl – 1 point
Results for the file test are.
Second – Vallorbe – 3 points
Third – Oregon – 2 points
Worst – Stihl – 1 point
The second and third were pretty much the same. I put them this way round and one of the lads who works for me (chief sharpener) put them the other way but said the same. Best and last seemed very obvious.
Also, best was only best because it took a lot off efficiently but was possibly a bit too vicious.
Last was bad cos all the filings stuck to the file and made it 'slippy'
Best: Save Edge – (10/10) – 4 points
Pretty Good: Vallorbe (8/10) – 3 points
OK: Oregon (5/10) – 2 points
Last: Stihl (3/10) – 1 point
I've given the chainsaw files a try out. My results are:
1st (best) – Vallorbe – 4 points
3rd – Save Edge – 2 points
4th (last) – Stihl – 1 point
Best- Stihl - 4 points
Pretty good- Save Edge – 3 points
Ok- Vallorbe – 2 points
Last- Oregon – 1 point
Best – Save Edge – 4 points - very aggressive and quick.
Pretty good – Stihl – 3 points - Almost as good.
Last – Oregon – 1 point. The worst by some degree – it felt half blunt straight from the packet.
Best - Shiny tang – Vallorbe – 4 points
Pretty Good - Shiny tip – Oregon – 3 points
OK - No marking – Save Edge – 2 points
Last - Black tip – Stihl – 1 point
Notes:
1. The first three files were effective at removing material from the cutters; the fourth file did not seem to bite like the others.
2. The shiny tang file removed the material effectively, fast and smooth; leaving a sharp and precise cutter.
3. The Shiny tip and no marking file were very similar in effectiveness.
4. The Black tip file seemed to clog up faster than the rest; it seemed not able to rid itself of the filings.
5. I've only used each file a couple of times each, the real deciding factor for me, on which file I would buy is the longevity.
6. I tried the files on both Stihl and Oregon chains, All the files seem to cut more effectively on the Oregon chains than on the Stihl ones; I don't know whether this due to the condition of the chains or what they are made of, I would like to investigate further.
Just had a sharpen up using all 4 files, and my thinking is as follows, worst to best - marked tang, unmarked, shiny tip and black tip.
Best – Stihl – 4 points
Pretty Good – Oregon – 3 points
Last – Vallorbe – 1 point
One member kindly did a test to see how the files kept their edge:
Endurance Test Set-up
Stihl RSC chain (virtually unused), mounted in a vice.
One tooth ground down to the marking on the top plate (6 mm material removed).
Each file was oiled (using WD-40) before filing, and the number of file strokes was counted.
Results
First tooth:
"Save Edge": 83 strokes.
"Vallorbe":102 strokes.
"Oregon": 125 strokes.
"Stihl": 145 strokes.
These results gives an objective reading of the efficiency of the files, and confirm the subjective findings, that I provided to you in my first test results.
