half price and free chain :)
Ha ha! Not a chance - I could do buy a bar and chain and get the same chain free and free postage?
:confused1:
  • Replies 122
sorry for derail (no pun intended)will you be selling at apf
I won't be Jonsie will have them on his stand (as well as the chainsaw mills) so you'll be able to see them in the flesh there.
:001_smile:
Having spent a bit of time on the US saw site, all I know is a lot of the US guys into tuning fit these bars on their saws and rate them highly!
I gather they do a nice light-weight bar where the inner laminate is a metal latice instead of being solid making the bar lighter - not sure if Rob has these yet.
Would be interested in trying one but not hinting:001_rolleyes:
The build quality is supposed to be better and in short they should last longer than other bars.
Also one thing I've found is that the company is receptive to new ideas i.e. the 46" bars they have made for me are the longest bar they have made to date - previously they made up to 42".
I wanted carving bars with holes or markings that give an idea of how far the bar is in the wood - they will be available in a few months.
I found that a refreshing attitude from a large multi national company willing to try new ideas.
:001_smile:
That's an interesting idea Rob, is that off the back of a carver? I'd like one but don't think I can wait any longer:001_rolleyes:. I'll settle for one without the markers.
Cheers,
Si
Ha ha! I haven't got any of those in this time....
The reason is because I have to buy a minimum of each type of bar and I've had to re mortgage to get these in!
They do x3 types:
  • laminated bars similar to Stihl and Oregon where x2 plates are welded and the gap filled with resin.
  • the lightweight bars - these are pretty unique in that the solid bars have sections removed and filled with resin (look in the pic below).
  • solid bars - single piece of steel.
The pic below is a solid bar with sections removed - these will then be filled with resin.
:biggrin:
Cheers,
Si
I wouldn't worry too much about it as it's only an add on type thing... yes Nick Speakman sent me a pic (as below).
I'm not too sure about this many large holes as I'd have thought it would effect the rigidity of the bar. But I'll be getting some carving bars with x3 or x4 23mm holes every 2" or so to help give an idea of how far in the wood the bar is.
But they'll be 4 months off yet....
:001_smile:
Yep Justin has taken a good fistful of bars! The courier was sweating a bit by the time he got them all loaded :biggrin:
Here is a breakdown of all the bar lengths in both Stihl and Husky mounts.
Bear in mind the bars up to and inc 20" are laminated and 24"+ are solid with replaceable nose.
I think Justin will be taking a full selection of Sugi bars to the apf (as well as Alaskan mills as I'm not there this year).
Stihl
Oregon code Sugihara code Additional info Retail (+vat)
120SPEA074 SL2L-0L30-A Laminated bar £22.00
140SPEA074 SL2L-0L35-A Laminated bar £24.00
153SLGD025 ST2L-3J37-A Laminated bar £25.00
163SLGD025 ST2L-3J40-A Laminated bar £26.00
183SLGD025 ST2L-3J45-A Laminated bar £28.00
153SLHD025 ST2L-3Q36-A Laminated bar £25.00
163SLHD025 ST2L-3Q40-A Laminated bar £26.00
183SLHD025 ST2L-3Q45-A Laminated bar £28.00
203SLHD025 ST2L-3Q50-A Laminated bar £34.00
243RNDD025 ST2T-3Q63-A Solid bar - sprock nose £64.00
303RNDD025 ST2T-3Q76-A Solid bar - sprock nose £85.00
363RNDD025 ST2T-3Q90-A Solid bar - sprock nose £98.00
40" - fits MS880,090 etc SG6T-3S100-A Solid bar - sprock nose £120.00
46" - fits MS880,090 etc SG6T-3S115-A Solid bar - sprock nose £185.00
Husky
Oregon Sugihara Additional info Retail (+vat)
158SLGK095 BM2L-8J37-A Laminated bar £25.00
188SLGK095 BM2L-8J45-A Laminated bar £28.00
158SLHK095 VH2L-8Q37-A Laminated bar £25.00
168SLHK095 VH2L-8Q40-A Laminated bar £26.00
188SLHK095 VH2L-8Q45-A Laminated bar £28.00
158SLHD009 VT2L-8Q36-A Laminated bar £25.00
168SLHD009 VT2L-8Q40-A Laminated bar £26.00
188SLHD009 VT2L-8Q45-A Laminated bar £28.00
208SLHD009 VT2L-8Q50-A Laminated bar £34.00
248RNDD009 VT3T-8Q62-A Solid bar - sprock nose £64.00
288RNDD009 VT3T-8Q70-A Solid bar - sprock nose £82.00
363RNDD009 VT3T-8Q90-A Solid bar - sprock nose £98.00
403RNDD009 VT3T-8Q100-A Solid bar - sprock nose £120.00
46" VT3T-8Q115-A Solid bar - sprock nose £185.00
