Zombie Plan....
windfall
Good idea on the easy lift!
I would think the brush cutter head with that triangular thing for weeds would be good, the zombies rip very easy.
Pole saw really should be just an added extra though.
Lure them into a skate park covered in Vaseline, with a huge chipper at the bottom with a walking floor to take them into the hopper.:biggrin:
  • Replies 46
Whilst Brainstorming my Zombie plan in the garden shed i accidently created a time machine...so while you lot are chasing Zombies with a pushing chain,i,ll be somewhere in the future terra forming woodland and becoming the first Arborist in Space
Might need a easy lift harness as well, holding a pole saw flat plays hell with the lower back! Would a hedge cutter head make less splash back??
You make an interesting point!
Today, with the assistance of two hoodies I found at the local poundland, doing a bit of glue sniffing, I conducted an experiment to test your theories.
The pole saw worked well, but yes there was some splash back.
The hedge cutter however was brutal, but ineffective. This resulted in the need for dispatch with the back-up ms660, not ideal.
They are loaded into the landrover now, off to the tip and home for tea.
will try some more experiments at the local town hall tommorrow to test use in confined spaces.
Might join you with a 201 on the confined space test
