Nonsense, I openly admit that MEWP's scare me, I feel its less dangerous to use the tree.
The tree has been stud there for years, through wind and rain, a MEWP will be set up on the day of the job, realistically which is more likely to fail???:sneaky2:
That's an interesting question, the tree is exposed to wear and tear 24/7 the MEWP for only a few hours per day and probably not every day.
Mewps arent (shouldnt be) set up in adverse weather so factoring all that in I wonder what the answer is, bearing in mind that after that last weather event I cleared up a dozen tree failures.
  • Replies 60
Big problem with MEWPs is that if hiring one, you have no idea at all whether a previous hirer could have overloaded it leading to a failure waiting to happen.
Big problem with a tree is that we don't know if the last winds overloaded it to the point of being an imminent failure.........
Dave your opinion although logical for you is not a good one. It places people at risk when they need not be.
In perspective I see the use of MEWPS as minimal in day to day operations. If your a climber - you climb as you must to remain current & fit enough to do so, however, when a certain tree presents itself (or large volume of trees) - either awkward - so usage would speed up the job to make it financially viable, or dangerous & making working the tree safer & easier.
Discounting there usage is not logical, either as a treeworker or business owner
I agree with you here.
Threads need pics:001_smile:
Here's me in 'my' 36 metre MEWP in NZ. (actually can't remember if this one is the 36, we had three but one of them was big)
Glad I hadn't seen this thread at the time:001_smile:
It had a recorded voice that told you when you were overextended etc....problem was it spoke Japanese... no BS..:001_smile:
Edit: No disrespect to those who suffered the accident, perhaps being a bit lighthearted here. I had no idea this could happen though.
Edited by Albedo
it's not simply overloading but you don't know how often a MEWP has had a large lump of tree battering down on its joints- lets face it- no one would tell the hire company that they may have damaged it:sneaky2:
