Don't Laugh...
New Forest DEAN
  • Replies 21
Cheap running tip; Get a long extention lead - and plug it in next door:thumbup1:
I only have an old electric saw, with no brake, my son finds it more risky than using a 088. Problem is that's the image of electric saws. A few on test would be good:001_cool:
I agree on the kick back. They are slower running but alot more torque at low speed and kick about alot more especially when starting in the cut.
  • 1 month later...
I'm looking at this Bosch 40-19S electric chainsaw for ringing - it's only a cheapo saw (about £110):
AKE 40-19 S - Chainsaw - Bosch Garden Tools
This should be a picture of the pile of wood I need to ring up - the biggest is about 18inches in diameter. I don't need it all at once, over a few years.
This is where you all tell me to get a petrol saw instead.....:001_smile:
Any thoughts?
Cheers - DEAN.
I don't know much about electric saws.
I think by the time you have loaded up the gen and gone getting firewood you will loose out on space with the gen taking up the room. Plus would a gen be powerfull enough to run an electric saw?
I got a gardentec saw from nettos when it used to be open, cost me 50 quid and so far all that has gone wrong is I lost a rubber vibration part, soon replaced with an old one from a stihl saw, fitted perfectly, got an 18inch bar with it and it's 52cc engine can cope with most timber very well. The chain brake handle is a bit touchy and only needs tapping to come on.
For your use I wouldn't bother with a stihl or husky, sounds like you wouldn't use it enough to warrant spending the money for one.
Any thoughts?
Cheers - DEAN.
The thought that struck me was yea, get a petrol saw and that lot will be logged up by lunch time or am I not seeing it all ?
Thats the lot - the front half of that pile is mine (the stuff just visible immediately behind is the neighbours - a 26 tonne artic load split evenly between us - it's a bit bigger than it looks because the picture was taken from above).
The question is - will an electric chainsaw be good enough for ringing three or four 8-foot logs at a time?
Next question - how long is a piece of string....
Cheers - DEAN
ps - I must admit the idea of ringing it all in a morning with a petrol chainsaw makes the extra cost very attractive....
Cheers - DEAN
Not sure if its you in the pic but I would not be dragging it over to a block . Ring up what you can on the stack . You get a little avalaunch now and then but as long as you keep your eyes open you will be safe . Get all equipment as near as you can to the action , splitters , processers etc . Don't make work , minimise it where you can . Good luck bu d !
