tipping cost
simonm
  • Replies 37
thats too much of a stretch. I am looking for some to try as cattle bedding, but we are kent/surrey borders
btw anyone else using arb arisings for cattle/sheep?
we use them.. good in open yards in winter.. and good to put a layer down a foot thick when you've mucked a shed out then put straw on top..
could deliver you 65 cubic yards in a bulker for cost of haulage and £6a ton for chips.. lot cheaper than wheat straw at £65 a ton
why would we not charge....???? a transit load of wood chip comes to around £6 when sold to stobarts... trucks have to drive down a private road past 5 nosey neighbours, through farm yard then up back to chip pile.... why would we let someone do that for nothing... if someones doing tree work and has a load wood chip and cant afford £30 to tip it then they shouldn't be doing the job... it costs me £105+vat to tip a 6yard skip at transfer station which would be same size as a high sided transit... what we are doing is illegal at the end of the day.... the only woodchip you are allowed to store is that that is chipped from your own trees on your own land or to store for compost to put on the land [which is a waste of time]... you cannot tip woodchip then resell it unless you have a waste transfer station..... if i could tip all my woodchip somewhere local for free i would as 6-£8 a ton for biomass is not worth the hassle of storing and loading...
Not sure on the comment re waste transfer station due to the environment agency keep changing the rules. Biggest problem with woodchip which people forget and get fined for is the liquid run off. We have to use IBC
containers to comply but that does allow us to process upto 75,000 tonnes per year.
Sadly our access isnt brilliant or Id give it a go. Otherwise wait for someone in the area who is currently paying to tip.
