Bowline as a termination knot
mikepage
The bowline is a very good termination knot, the main issue being the inability to tie it tight enough to cinch down on to the carabiner, with the theoretical risk that when unloaded it can side load the gate(as born2trot said). The anchor hitch for example eliminates this risk as does the buntline.
Hope that makes sense:thumbup1:
I always use a bowline as my termination knot..with a krab..or with larger pieces in a running bowline. I hate spending needless time tieing in and having the groundies tieing and untieing knots. As long as its within your swl (and it only reduces the strength of the line by 30%)...tie it.
Edited by arbogrunt
Tis the termination I used for ages then switched to the Anchor hitch and still use it. As for uncliping the Anchor,I don't, I un-tie it, advance the line, tie back on,easy. What benefits are you thinking of?
Well, er, the fact you don't have to tie and untie your termination knot. I can see there are benefits to untying it as well mind.
bowline with a yosemite is all i've ever used, got a decent weight to it for chucking it higher in the tree. dead quick to tie and with a bit of a loop on it keeps it clear of my hitch so no risk of it catching on it. and unlike with a spliced eye i can change the end of the rope i'm using on a regular basis to even out wear and tear on the rope.
