hey skyhuck, where did you learn that trick on chogging down with leaving the saw in the wood. i've only seen one guy in oz do it, thats who i got it off. interesting to know if the same tricks are over in england.
  • Replies 162
Self taught mate.
I've never seen any one else do it, but then I've not worked with that many climbers.
i don't feel like such a stand alone cowboy after this thread. i've never seen too much harm in lowering or zipping the occasional piece off my line.
here's a handy little trick i picked up. if your too far from the lowering line to be flicked to you(you also have to be reasonably below the lowering point), rather than tie the krab to your line and pull it up. get the groundie to clip the krab around your line, he then holds your line tight and pulls on the lowering line the krab then slips up the rope to you. easy and simple.
What gets me every time i read something like that, is how simple it is, so how can I have missed it for 25 years? cool as. thanks.
heres one courtesy of Chris Headdon.
When chogging down:
On over and under cuts on larger diameter chogs (that you cant break off)cut a small dip in one side ...hey presto clean break!
don't know if thats been posted already but cheers chris its worth its weight.
use half hitches to lower multiple branches works a treat on whirled trees (monkeypuzzle and the like) but watch out for the weight snapping branches before you get to cut them...saves petrol though.
step cut a few braches at a time so as to get more cutting done while you've got your saw(make 'em good and not tangled)
if your having to throw branches a bit of a way to hit the drop zone pile them up and do all your cutting then all your throwing (within reason), handy one for wide leylandii hedges!
If your felling a stem on a hill/near a target which may take a wack with the stem kicking up or you dont want it rolling use a piece of lowering rope (2-3m) to do a snatch (i guess) cut some notches below fell cut (front and back) for rope to sit in, tie rope above and below fell cut so it holds and cant go anywhere, fell away. remember the ropes gonna try to get off the stump more than the stem!
Branches always make good hooks, strops can be good for security on handhelds.
Sometimes leave your 200 hanging in the middle of the tree if you don't need it for tips.
If your working on pollards and need to cut and chuck get a piece of rope, choke off the new growth, cut from one side while tightening the choke, throw the whole lot to your groundie.
Self taught mate.
I think that often many problems are overcome by the self taught. The open mind to new and exciting methods is prevelent in those who are self taught. Farmed climbers tend to follow their mentors styles. ( college rant alert) and may limit themselves by doing only what they where shown.
I'm not convinced that my tricks are unorthodox having read the ones above :P
Apart from half cutting limbs until they point at the ground, then letting them go
so they drop at the trunk.
ermmmm...
Waiting until the customers not around before making a massive section fall when the customer has been watching me diligently dismantle the rest piece by piece. :-)
If you cant afford to buy a decent climbing line then you should charge a bit more, or find another industry.
use ikea bags for rope bags, cheap as. makes it quicker to afford the dearer stuff.
use old tyres to drop chogs onto when trying to save drives, pathways, tarmac etc.
So many things we do on a day to day basis without thinking, then when you see them wrote down, it makes you realise you were never taught that. My favourite was flicking stubs etc with your bar just as you get right through them.
