Running the risk of asking a stupid question here but as I'm new to wood stoves I'm gonna go for it.
When I return to my stove in the morning and find a nice pile of hot embers , what's the best way to get it going again ?
Is it as simple as more paper , kindling and logs or is there a trick I'm missing.
Some one I used to know reckoned he just opens the vents and his would burst into flames of it's own accord ,so I'm either doing some thing wrong or he was mr Billy bullpoo..
Thanks in advance
  • Replies 26
Never use paper, not even to light it initially. It floats up, sticks to the lining and can have a secondary burning.
surely this can only happen if your chimney is skanky already, the paper or leaf or ember or whatever sticks to the side because it is full of creosote up there. if your burning good wood and sweep it every so often then surely it'll be fine to send a bit of paper up it?
i may be wrong but this seems like one of those "if you eat an apple pip" stories:001_tt2:
Bellows is the answer.... I got some antiquey ones off ebay and I do not know why I didn't get any sooner...
Ruddy amazing how easy it is to get embers and some kindling and get it going again.
It is possible to relight the stove by opening up the dampers in the morning but you will need to put a big old log on the stove just before going to bed and not laying in too late in the morning:lol:
I usually do this at Christmas when we spend much of the day in the room with the burner in it.
Morso recommend newspaper, be unusual or a whole piece to go around the top baffle intact, thats about a 160 degree bend in most stoves.
relight, yes kinding if you have decent embers, failing that rolled up newspaper with kindling on top.
A
Hi, with ours if the embers are there then a good stir and put on a few small bits and open the vents right up. If it has gone out then i use a firelighter dont bother with kindling any more lights very easy if still warm from day before.
Hope this some help
Cheers Chris
