Lol the one you still have is my favourite though when it's working!! Maybe time for some new ones!
You may have heard it wailing a mile away around 5.00pm on Sunday today! Seems OK now and idles/revs out fine - you will have to see what you think of it now!
Latest news on the 880 - new piston fitted, in the process of cleaning the carb - noted the H screw was at 1/4 turn NOT 1/2 as per spec so probably the route cause of the seizure.
Pressure check was 100% fine: -
JB weld my friend - just clean up the surfaces with strong solvent, soap and water etc:thumbup:
Just got some ebay - will let you know results:thumbup1:
It all happens at once.
The 880 needs a new coil, piston and barrell (18 month old) and the long reach hedge cutter got through a gear head in 5 months.
18" bar on the 341 seized the other day aswell.
LDV needs a new tyre and tracking sorting.
What next?
OEM piston?
Did you remove the limiter caps and screws to clean the carb?
According to my literature the standard setting (limiter caps in place) is 3/4 turn out on the H. The basic setting (having removed the limiter cap) is one full turn out on the H. (For the HT-12D and HT-12E carbs).
The newer Walbro carb is different.
Edited by Megatron
OEM piston?
OEM piston - no, used aftermarket after consulting the customer and going through the prices - tested the old piston for steel inserts and found no steel present - wouldn't Stihl just increase the aluminium thickness to increase strength and the aluminium would conduct heat more efficiently?
Limiter caps are off - the saw seized so it is important that I know where the tune is, once I have reset the mix, they will be replaced. The saw was set at 3/4 on the idle and 1/4 on the H screw with caps removed, the rear filter cover says H=1/2 L=1/4
Having very roughly got the saw started, the L is at 3/4 and the H at 1 turn, I will do a tune before the saw goes back to use. The carb is a tillotson of a considerable size:thumbup:
The damage on the saw was almost definitely caused by the H setting being too lean, possibly by removal of the caps and setting to the settings on the cover - I will leave this on the rich setting to give the piston a chance to run in especially baring in mind the sort of work it will do but will rely on my tach to do the final tune.
Happy so far:thumbup:
Edited by spudulike
What next?
ouch :thumbdown:
So the 880 is running, needs a tune, MattyF 357XP has been run up for 30 mins and tached at a conserative 13,500 and it idles fine and revs very swiftly. Time will tell if I have cracked this saws problems!
All I know is tat it has good compression, is 100% airtight and the carb is definitely the problem if the idle goes again!
Got a Husky 136 on the bench now - needs a new sprocket and tune.
