If you can get hold of the metal caged needle bearings, they are significantly stronger than the fibre ones!
Any idea where to source suitable metal-caged needle bearing for MS261 from? And/or manufacturer or specs (dimensions). I would really like to get hold of a couple.
I have seen one filtted and thnk some of the Chinese manufacturers do them. Try a specialist online bearig reseller - probbly your best bet!
OK, the caged needle roller bearing for the MS 261 has dimensions 10 x 14 x 13.5 mm (internal diameter, external diameter, length). But I have only been able to find bearings with Polyamide cages (typically designated "B 10 14 13.5 TN", where "B" designates "Cage with one row of needle rollers" and "TN" designates "Polyamide cage").
If anyone can identify sources of this bearing with a metal cage, please post info/links.
PS: This should have been posted in a separate thread –*sorry for the derail!
I bought a metal needle bearing for my 261 on eBay, and has not broken since. I think it was from mister solutions.
I think they did the metal one, how about checking:thumbup:
Where can you get a 560 crank from ?? Can not see them on pdf parts lists ? Failing that can you split it and replace the Conrod and replace bearing as it's supposedly three piece ?
