As said the tops are interchangeable. Ive used a couple of the hutzl 026 carbs and never had an issue. They also come set pretty well and barely need anything but a minor fine tune.
At the mo the hutzl stuff seems to be taking little over a week to come thru so I shouldn't think you will be waiting 3.
Thanks for the added vote of confidence in the Huztl carbs. I thought I'd read on here that people thought they were very good at the price.
I might have been a little disingenuous about the delivery; my first purchase took 3 weeks, but looking at my last item bought from them it was only 10 days.
Sod it, I'll buy two!
The 357 is mine :blushing:. I bought it as a part ex, and had it delivered to Spud. I spent over an hour stripping and cleaning my 038 before I sent it to the buyer. He obviously didn't do the same for me!
Sorry mate, it's a bit like being an IT consultant and being asked to clean off someone's dirty keyboard!
At least the previous owner of the Husqy had to pay extra for all that crap he sent with the saw!
Had to clean the workshop floor after cleaning it, half a can of brake cleaner used on it and the compressor:001_rolleyes::lol:
Had a run of them lately - fed up with oily woodchip in my hair:thumbdown:
I hear the ladies go mad for it though!
I sharpened my mates 200T on Friday, he came back a few minutes later and I had it in bits with a can of WD40 and airline...
I can't help myself!
Hope you cleaned inside that chain brake, it clicks nicely when you do......most don't :001_rolleyes:
Chain brake, clutch drum, cylinder fins, flywheel housing, and what's with that stupid plastic bit screwed inside the flywheel housing? The torx screws are a different size and I can't see it's point!
It just directs the air over the engine! ....and holds lots of crud!
Every bloody tool I've picked up (well not that bad but almost).
currently stripping down an old ms180 that the trigger wire has snapped on. The reason I'd picked that up was that the MS170 i usually use has a very leaky oil tank. Then my phone packed up, and after I'd finished the tree job, I had to cut some grass, the mower handle has snapped. GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR.
Hey, got a sthil 201 TH that the chain brake coil keeps shifting into the path of the chain, causing it to catch and jam or just blunt the chain. Sent it to the dealers to repair it, they replaced the break coil and seemed fine for a week then just started shifting again, any advice?
Sent from my C5303 using Arbtalk mobile app
Get some pics up, Coil???? is this the brake band or spring? Sounds like the side cover may have some distortion in it but can't tell from your description.
