Chain Sharpener?
Big T
  • Replies 30
Forget the electric and use a file.
+1
- better sharpness
- sharpen anywhere (no need for power outlet nearby)
- faster (except when chain is totally ruined)
- handles any chain size
- longer chain life (only remove the material required)
- Easy
- Cheap
Edited by morten
echo the above comment. for the occaisional user who may use a chain or two a year, a file is much easier.
Portek do a chain sharpener thats mainly plastic and you do get what you pay for at £40, however ive not used one so dont know if they do a good job or not.
i use the equivalent model to the oregon pro bench mounted one and it gives good results, its good for sorting out mullered chains and is about as quick as a hand file when just giving chains a tickle. it keeps angles and the amount taken consistent so the chain will cut straight, which is handy!
