Where applicable please could you list your chosen application for the knot in question, size cord you prefer, length of cord(or loop in some cases), pros and cons, etc etc...anything you can think of really. Thanks
Type of french prussic, tied with a single cord. Related to the machard tresse tied with a loop.
The legs alternate which one is on top at the braids, unlike the valdotain which is the same leg on top each time.
  • 4 years later...
I guess about 30cm not including the bit need to make a loop in the end. Buy a metre put a scaffold not on one end tie the hitch with the live end and see how much you need to cut off after putting a scaffold on the other end? Personal preference comes into, amount of cross overs, rope diameter and hitch cord diameter.
Edited by Daythe trees
  • 7 months later...
Use it on my lanyard, with a 75cm eye and eye. Generally 3 wraps and 3 braids, but will change that if need more or less friction.
Also use it with my hitch climber - 70cm i&i 4 wraps, 2 braids, OP 10mm onto 13mm climbing line.
+ Grips well, easy to tend slack.
- on hitch climber fixed eye on my climbing line can sometimes stop the VT from biting, but I am used to this happening occassionally and can quickly correct it one handed.
I use it as a friction hitch on ddrt with a hitch climber system occasionally and also on a work positioning soft lanyard.
Ocean polyester e2e 8mm is my preference.
