One handed chain saw use
Alex
Do you use your top handle saw one handed
44 members have voted
  1. 1. Do you use your top handle saw one handed
    • Yes every day
      35
    • Yes about once a week
      6
    • Hardly ever
      3
  • Replies 79
this is a bit off topic but there is alot of talk about chain saw use, lolar, haveing the right ticket etc but in my experents the most common injury is a bad back.If the money spent complying with all the hse regs, was spent reduceing manuel lifting of wood would we be better of ?.
I have the scars from over 80 staples in my back, the result of 3 spine ops. Can climb day in day out (at my own pace) without any problems. Spend a day on the ground and im knackered. IMO (and my backs) ground work is far higher risk than climbing. You must appreciate and uderstand how to lift/drag etc in a way so as not to shag your body today, tomorrow or in ten years time.
My back problems were not caused directly by lifting etc. I hope none of you ever have to go through the same as me. Learn how to do things properly within the limits of your body, dont be an :asshole2: , it will come back to bite.
i try to stay psyched that lifting is compressive on bad back; while climbing is opposite; light traction on back.
i've got 3 blowed out disks on right side. So; the left works harder and goes into spasm from tension pulls on it as it tries to make up for right side when lifting.
what does a man who only uses a chainsaw with 2 hands and a mokey have in common
They both *uck about up up trees
only joking alex
lmfao,
if you used 2 hands all the time then you might as well get the ipaf out and just stand in a bucket all day long, some good work can be done out streched with 1 hand as long as your not being silly, there is certain limits 1 hand can do but each climber SHOULD know these limits
Rules are made because morons need a nanny.
When I make a single handed cut my body, legs and feet are safely away from the fall of the saw (including deflection).
If there is a danger of kick back I won't do it.
If the saw is likely to pinch and fall with the cut limb I won't do it.
Work position and situation asssessment is key.
Otherwise, yes there is risk in all we do. Its up to the individual. I think its ok if your sensible.
