Harness weight limits
RobArb
When people buy a new harness do they take weight limits into play?
for example i've just been watching a video on the treemotion and it says there is a 220lb weight limit which is only just under 16 stone?
Are there many heavy climbers out there? i'm only 14st myself but it does make you think:001_huh:
  • Replies 32
How can it have a weight limit that low?
I thought the buckles and webbing is rated far higher than even a really,really big fat person.:confused1:
It is all rated much higher than that but will have a WLL of one person, which is often described as 100kg or 220Lbs.
So it probably has a MBS of say 30kn. Which using a 10:1 safety factor gives you 300kgs. But its intended for one person so its WLL is one person, and for easy figures that is described as 100kgs, which if converted to american is 220lbs
It does not mean that someone 105kgs cant use it.
