On that Lewis winch, it says it pulls 4000 lb on a 3/16 cable. Do they mean 2 tons on a 3/16" (4.8 mm) cable?
I'd be interested to know what sort of cable they use, and what sort of safety factor they're working to. The only cables of that diameter I've seen have minimum breaking loads of around 2 tonnes.
I presume that's with a snatch block rather than a straight line pull.
  • Replies 23
Iv'e got a lewis winch and run it off a 372. It will only pull the 8000 pounds with a 90cc saw, through a snatch block. I find the 372 fine. I had a few problems with their wire rope, so got myself some dynema rope of the net, reels in a lot better than the wire rope. great for pulling timber out of awkward places and for pulling the chipper about in tight places. very useful piece of kit. great for quick simple pulling of small trees. But stick with the tirfor if pulling over large trees.
  • 1 year later...
Been thinking about a chainsaw winch for a while as I think it could come in handy for some of the thinning we end up doing where most of it is shortwooded from stump but there's often a few bits that need pulling into reach and trailing the tractor and winch down is sometimes a bit overkill, but quicker than tirforing or dragging with the crane and a selection of strops.
Anyway, I've just picked up some work on a site I was last at 4/5 years ago (maybe more) when I still had the Carraro. It's a long valley with some real nice Larch and there's a fair bit of smaller diameter firewood grown up in among it that's been drawn up - probably very little over 12" diameter and mostly 8-10"
In the past we've cut it fairly short and hoyed it downhill to the track but some of it's a bit too wide for it and also some of it would be better off uphill.
I'm thinking a chainsaw winch would be a useful addition to the fleet and think it could be one of those things that gets brought out more than I'd have first expceted.
So far, the Lewis seems to have had nothing but praise and seems to be the cheapest too (about £860 inc vat) but I've no experience of using one.
Are they up to doing a reasonable amount of skidding on smaller poles? Are they much cop at pulling out hangers?
I'd probably give it a try as a haulback line for when we're doing banksides with the tractor winch too -interested to hear if anyones tried it and how well it went.
4000lb = 2 ton US,
i.e. short ton and NOT long ton, as ton in the UK is long (~1016kg), while metric tonne is the 1000kg one noted by the speling.
  • 3 months later...
have alot of trees (mostly small) to drag back from streams in areas where machines cant reach. do i need any special ticket to operate a chainsaw winch ?
large utility job, need method statement for everything
I have a lewis winch, I run it on an old Stihl 024 and changed the wire rope to dyneema, no sprags, no crushing the rope when you wind the rope in and it makes it a bit lighter to carry about. I have used it to pull ute and chipper onto site, pull over some pretty butty trees.
I would like one of the Honda capstan winches so I can use whatever rope I have at hand but they are $1600 USD
