8 hours ago, AHPP said:
Anything more like a keepering manual? How to arrange vegetation to hold birds, when to feed, wtf does dogging-in mean anyway, where to put your guns and beaters etc.
Dogging in is getting birds back into your cover strip using a spaniel usually ( but not exclusively ) some time before you do the drive . In a nutshell cover strips should be on higher ground ( unless they are going to be blanked into higher ground before the drive comences ) Pens should be the oposite ground to the cover strips . ( birds will usually fly from cover back to the reliece pen they were reared in ) . Feeding can be by hoppers or you can hand feed by whistleing the bird and feeding on a straw ride . You want the feeders in the cover strips . This is very baisic . There are other subtlties .
My Sea Pattern Brown Bess. This was given to the Swedes amongst thousands of others back in the 1800s by the British when the Russians were getting sporty.
  • Like 8
Do you fire it?
There's a place nearby that has a gathering of black powder enthusiasts, the whoomph sound is quite different from the crack of guns on the adjacent army range.
4 hours ago, openspaceman said:
Do you fire it?
Yes,I fire it now and again. Its alot of fun.
I looked at those a couple of years ago. Hugely confusing selection of models. Some rifled, some smoothbore, some belt fed, some rotary mag, some pellet, some bb, etc. No logic to the combinations. Gave up.
Post a group when you've got used to it.
This is my Smith & Wesson " trippel lock" revolver in 45Acp. It was bought in 1915 by the British Government to replace losses on the western front. Only 5000 were purchased and not many remain. It was originally chambered in 455 Webley but someone has shaved the cylinder so it takes 45acp in moon clips.
This revolver bears no commercial British proof marks so probably was dropped to the Norwegian resistance during the war,SOE dropped alot of non standard stuff early on.However you never really know,it could have been captured from the British Expeditionsry force over here or someone could have swapped it for a blowjob...
Its a hello of a nice gun and its fun to think how it ended up here.
Well....sounds like we know how it came into your possession at least.
  • Haha 7
Yup, will do.
This is smoothbore BB, load from top like a stick mag.
