On 05/04/2025 at 17:36, Stubby said:
What does your local FAO require to make him happy ?
Had a good one for a while, after he retired the next one said I "should" lock up my shotgun ammunition.
I buy pigeon carts by the 10 000 and split with my friend, so not happening but eventually he conceded that since the guns were in a cabinet bolted to the joists and firearm ammo and bolts in a safe also bolted to the joists and all in a locked gun room with no window was as good as it was ever going to get.
I had a change of FAO whilst I lived in London.  On renewal, he asked why I needed a .223 as well as a .17hmr on my ticket?
I replied for Fox control.
He then started to lecture me that a .17hmr was perfectly good round for foxes.
I replied that I am sure it is but as you well know it is illegal to use for culling foxes in England.
I think he was either clueless or testing me.
No drama I moved to Norway the year later.
Fairly sure that’s not illegal. Someone correct me, stating some law if I’m wrong.
Edited by AHPP
After a bit of searching go it would appear it isn’t illegal but not necessary ethical.
Seems to change depending on the area or the FAO.
I know in the North East if you applied for a .17hmr specified for Fox control trip it would be knocked back.  At least in Teeside it was.
WWW.THESTALKINGDIRECTORY.CO.UK
I understand that here in Essex they don't deem the .17hmr suitable for foxes & that you can't get it on your...
I’ve been fancying a .22 Hornet recently. The thinking man’s HMR. Importantly,
rimmed. There’s a thread on the American Single Shot Rifle Association forum of bloke called Bailey Bradshaw making an absolute sweetheart of a Hornet double rifle.
22lr or 223 personally, hornet is going to be expensive to feed as it's an oddball and you won't be gaining much especially when you can get surplus 223 cheap.
Was pushing 125m with the 22lr the other day and keeping it around 4", need a bigger gong to push 150-200.
You soon get bored with 17, it's too bloody loud but amazing watching it explode on a steel gong.
I don't have guns now, but I started with a .22 Win Mag rifle, hoping it would be cheap to run, and big enough for foxes. Ammunition wasn't widely stocked, which made it a pain. It was accurate, and would stop small things at over a hundred yards easily, in fact it had the same energy at a hundred yards as a .22lr had just leaving the barrel.
It stopped every fox I hit with it, but it just wasn't powerful enough for that.  The .223 which I added to the arsenal solved that problem.
The current guidance states you can be granted 17HMR for fox. I know some forces may be reluctant but you could argue your case...
Can you still get cheap .223 milsurp? Down here it isn't cheap any more, and I wouldnt use it on foxes.
Edited by Paul in the woods
