some of my missfortunes!!...whats yours??
Sully
Oh no, they're coming back to me now!
Reversed Unimog into drive way, dropped chipper, engaged chipper and pushed a load of brush in.
Upon turning round to pick up more brush I noticed the woodchips flying over my head and through the clients stained glass window.
I'd forgotten to turn the chipper spout into the Mog!!
Sent with my iPhone from me, to you!
  • Replies 175
A month ago I was doing skip truck work jumped into skip with one hand on side flinging legs over top, the skip was resting on the back of the truck and dropped about 6 inches which completely threw me out of sync. Mid flight gravity seemed to tractor beam me to the floor. I intercepted the side of the skip bashed left thigh which left a 10 x 4 inch beautiful dark purple bruise, which didn't hurt that much. But my left hand took the fall on the fingertips, which still isnt right.
Daft thing is I had previously thought of being careful as I knew skip was resting on the truck
What a prize muppet you are!!! At least you didnt loose your finger like me!!! But at least have a little party trick to show for it :D
Dismantled an oak, wiped out 5 different fences, 2 sheds and a patio, dead birch removal took out a fence, did another in the same area a few days later and took out another fence, another dead birch took out some slabs, pruning a eucalypt, took out a hedge, plus other minor damages with trees
Sent using Arbtalk Mobile App
jesus......
threw a ring off an Ash and watched in horror as it disappeared through a man hole cover disguised as a pile of sawdust.
felled a fair sized Beech stick perfectly between a wall and garage, the stick then rolled in slow motion 90 degrees to the left and settled nicely against the wall leaving it at a gravity defying 40 degrees.
replaced a shed for the cost of the job. sold the firewood to pay the day.
rolled a stump grinder.
drove a mini digger into a septic tank.
discovered the reason why you need to be extra carefully where you set down the fuel can when working with a Jenson chipper.
the list goes on and is ever expanding............
