Ok felled my first proper tree today. Up till now it's been stumps and garden sized tree. Not as easy as it appears. About 30 degrees to the right of my target. But it was a safe area where ever it fell so was a good practice. You honest opinions gentlemen?
You don't actually have a hinge at all there, it looks to be pretty much just a step cut, you're lucky it went any where near where you wanted. It could have gone where ever it wanted :001_huh:
Did you even cut a gob?
Edited by skyhuck
I think the hinge is the bit of bark still attached.
I give this a score of 0.5. :laugh1:
cheers, steve
cheers, steve
Oh you are the Craig of the panel I see :biggrin:
Yep I can see a gob has been cut but but the bottom cut of the hinge has gone in further than the face cut so it's turned into step cut. The Ralphy left over suggest it may of started out as the Danish pie cut but the tree had decided it had had enough by then and went over anyway :001_smile:
TSI. Evesham
(Tree scene investigation)
I agree and disagree.... the front cut (which I presume was his first cut) appears to be slightly sloping downwards and from what I can see in the photos I do not believe a cheese of Brie was removed.... it appears to be a single cut at the front.
He has followed up with a level rear cut that appears to have not gone across the diameter of the tree. The remaining bark section may have slightly pulled the tree to one side as it fell, before it tore out.
Never been called Craig before. :thumbup:
Definitely a 0.5 from me.
cheers, Steve
p.s... I would score the flail hinge far higher/ 2 out of 10 for that one.
cheers, Steve
2/10 what about artistic tempriment got to give another 3 for that.
Your right about the Brie. The gob looks like it's 50% and he blew through the gob to me
