Was interested to know what everyone uses while climbing. I've seen everything from the usual silky zubat to small folding saws and even saw someone usual a bowsaw from a mewp!
I've got a 300mm silky zubat and as of tomorrow hopefully a saw pod for it.
So, what do you use?
  • Replies 32
Hi stig of the dump,
Silky, great brand which you can't go far wrong with. However, we have had an increase in demand for a new brand called 'Cutting-Edge', they pop up at all the usual trade fairs. The most popular sheathed saw that we supply from that brand is the 'Bronco' 310mm.
The secure-to-scabbard locking mechanism is designed with assisted rollers built into the scabbard sheath giving you optimal safety & storage comfort with an easy one-handed release action, and used with a Sawpod makes this saw perfect professional pruning, trimming, lanscaping, forestry and gardening.
Any queries, please PM us. :hello:
Regards,
Jason.
I have a samurai as it was cheaper than the silky equivilant. If claimed you can cut plaster board with it so I did and now its a bit blunt. Not impressed. Think it will be a silky again or the BQ one above as I must admit I've had one before and aren't a bad bit of kit at 13 quid.
Gomtaro Pro
Small and compact enough to be comfortable in a sawpod and has small teeth at the end for smaller branches, which is really handy :001_cool:
