Very nice wolf man ... This tree had a great natural line to follow , some thing I was trying to explain in another thread.
I don't have a problem the hair cut reduction it benefits the tree so much better than a good old hat rack .. I need to dig out a pic of two limes both done at the same time , one hat racked by a colleague the other one imo properly reduced 25% , obviously the hat rack provided more light at the time but 6 years later it was atleast two meters taller and denser... Infact the reduced tree just required a thin and minor reconstruction, whilst the hat rack needed a proper reduction.... It also had some cavities unlike the other.
I go by the view if you hit a tree hard it will make up for what it's lost quickly and then a lot more to compensate for what it's put out and to get some more back!
Nice work on the Lime Tony, should come back nicely.
I was asked to reduce this large Plane recently to reduce weight and minimise risk of failure as it has a large cavity in the trunk.
What a pain it was!! Virtually all branches got hung up, and the dust was horrendous!
Sorry about the after pic - it was getting dark by the time we finished.
That my man was a very fine job done:thumbup1:
My thoughts exactly. IMO the vast majority of hat rack reductions are carried out by either improperly/untrained or lazy tree surgeons.
It takes a bit more effort and time to do a proper reduction but the end result is a more natural looking tree which will respond much better to the work. The biggest compliment is when a client says "you would not know that the tree has been worked on".
Your pictures of the Lime would be a great educational tool for clients that think harder reductions = more value for money.
Yeah theres a nice rot pocket full of water on the top cut but the wood is hard and not pulpy, according to the owner its a watering hole for the local birds.
Here is a Bay from the same job, its brittle and yellowing and the bracket is the second one thats cropped up in the last 5 years.
Ill be back in a couple of years to keep the birch in check unless the Bay gives up the ghost in the mean time.
