14 hours ago, nepia said:
PXL_20260116_112645328.thumb.jpg.b420be95d9029f1a16e4065a998707fa.jpgA friend locally has a pair of huge wooden beams to go; 14'x18"x12".
Apparently made of a tropical hardwood - 'if you cut into them the wood's red'.
Came from the railways where they were used for supporting heavy equipment.
Where/how could these be moved on?
Cheers,
I am sure someone will have a use for those beams.  The problem as always is finding that goldilocks customer.  Many customers would want lots of them, and others will only want a 6ft piece etc.
I think the way to go is Facebook marketplace.  Include photos and as much info as possible in the advert.
I will say though I don't think they are tropical hardwood.  Zoom in on the end grain and you can clearly see the springwood and summerwood.  It looks exactly like a quality softwood - pitch pine, or even larch or douglas fir.  This doesn't make them any less useful in my view.  If you want to get a better idea cross cut a couple of inches off one end.
That's useful; thank you.
I'll definitely make a cut and take pics.
FB Marketplace does seem the way to go these days.
Cheers
If they’re ex rail they could be cresoted or the old quality tantalised, if so would make some good bridge main beams for a stream or drainage channel? Don’t expect a fortune then won’t be disappointed? Try a farm, plant auction?
The larger one looks more like Larch or Douglas fir, which has very distinctive smell, the rings look too wide for decent pitch pine.
Cut the end off and take a close up of the end grain, then compare it on the wood database.
I got about 30 seconds to brush a saw over the end yesterday.  I can't say the smell was distinctive; not one that shouted Douglas at me but that is a possibility isn't it.
Douglas or larch I would say.
