2 hours ago, KiwiGardens said:
Hi there, i am currently running a 28inch bar on a Husky 365, as it has plenty of power could anyone let me know if it would take a 36inch bar please.
There is no right or wrong answer with bar lengths but that sounds a bit extreme.  I can't remember if the 365 is 65 or 70 is CC, but the old rule of dividing the cc by 3 is about right, which would be 23, so it sounds like you are already pushing it at 28 inches.  Personally for a 36 inch bar id go for a 90 or 120 cc saw.
Also unless you are milling, there are very few situations in the UK where 36 inch bars are essential.  If you are milling, this is even tougher for the saw and I would still to a 120 cc saw for a 36 inch bar.
  • Like 6
And .404 pitch chain .
If you have to run a 36" bar a bigger saw would be advised.
I think 24" is the recommended longest bar for a 365 and you are way past that.
I'm sure the USA has plenty of people doing it with ported 365 and full skip chains but that don't make it right!! :)
If your chain is sharp and you are cutting softwood you might make it work?
The simple answer is no, av system not up to it, nor is the oil pump, 28” has to be on the slippery edge.
I have 365 and I have 2 of them , can’t believe it can drag 28 inch properly , even 24 is at the edge with full skip, both my saws is modded , mufflers and port cowers grindet! Best bar for them is 20 inch or 18 in my opinion.
28' is already too long. As others have said and the reasons given. Rule of thumb ideal maximum bar length on a saw is one third of the engine cc's. Approx
Edited by pleasant
On 06/12/2025 at 11:47, Oldfeller said:
what are you intending to cut with a 36" bar?
Who said anything about cutting? He just needs a cool looking avatar picture for his ‘socials’ profiles. 🤣
If you can get a bar to actually fit, next step is to cut the sleeves off an old formal shirt and buy some elasticated braces!
Edited by TurtleWoods72
