Ok, I know I know bbbbut
Back on the farm and in the Woods I cannot move for fear of violating some ‘elf and safety rule.  Most of which are fair but a lot are bleeding’ obvious.  Caution on working on slippery surfaces, caution on ladders and working from heights, caution when using teleporters when reversing etc
Now staying in London at the second hotel and there is again a faucet on both the sink and shower with no indication whatsoever of which  direction to turn it for hot or cold.  In the old days of separate taps you would have a red dot on the hot tap and a blue one in the cold.  Years before that it would by experiment I discovered one changed the direction from shower to bath but not before I had  received a blast of red hot water to my head from the shower.  I have like all of you learned that turning the faucet to the left would mean hot and to the right cold.  But this faucet was mounted vertically to confuse further and there was no indication of which faucet controlled the shower/bath and which the hot cold..  It seems that there is no standard as each hotel I stay in is different
You would have thought that things would improve over time especially where very hot water is concerned.   Rrrrrrrrrrrr
9 hours ago, MrNick said:
I wasn't grumpy until the word faucet. It's a f-ing tap 😄
Apologies for my Americanism.  I did use the word tap to describe earlier tap warnings and I thought that faucet was the new word to describe these single devices that control flow, temperature and direction with one lever.  Every day is a learning day.  I will in future refer to them as embuggerment devices!
On and on then!  Or should it be on and off.  The problem is I do not know which way to turn it off!
On the tap in our new hotel room there is a red blob and a blue blob  The problem is that when you turn the lever in the direction of the blue blob, the blue blob disappears and you are left with a very prominent red blob facing you.
They need a fixed line to show which blob is active.  It is not rocket science!
Grumpy Old Man moans... where to start?
How about the appalling use (misuse) of Road Closed signs?  You cannot trust them either way and if they're legitimate you can't tell what road they're referring to.
My starter for 10...
  • Like 7
Excellent point.  And then if you go past the sign (as they are so often obsolete) and then people shake their heads at you when you are forced to turn round as it is actually closed!
This thread is made for me!  I have wondered in the past about starting a thread about terrible design, but this is even better.
Following on from the taps mentioned earlier, what about automatic taps that simply do not work.  I first came across this in 1997 (so etched on my mind was the trauma of not being able to work a tap) and one would think they would work well now.  But no.  I know a set of three newly installed at a local sports club near me where you have to dodge between them all hoping that you will get enough little dribbles out of each to finally wash your hands.
