  On 22/03/2025 at 12:35, monkeybusiness said:
I’d suggest that quite a few commenting on here (along with at least one person on the site that is the subject of this post) would benefit very strongly from doing their windblow ticket as a bare minimum - there are some worrying advisory suggestions being bandied about. It is clear that several here have no winching experience, which should really be the first approach considered when dealing with hung up trees.
Expand
I agree. Imo, it's a foresters job rather than an arbs. Or an arb with the knowledge and experience of removing windthrown trees.
If it was hung up on someone's property then it's a different kettle of fish.
In terms of winching, and speedy dropping, on rewatching...quite honestly they could have pulled the hung up crown down with just the tractor and a rope, *maybe* (install the rope remotely in the problem tree high crotch and brute force it sideways back along the road). Wasn't that massive of a tree. Guessing 14 inch at the ground, weak root system, not much holding it in the other tree. Cut a sideways hinge in the root end if necessary.
Assuming they had pull rope..
Screenshot_20250322-203240.thumb.png.d34bcaeb5b717796155ad5382adf5376.pngScreenshot_20250322-203348.thumb.png.451f4ad1f74d53558c902489d929c008.png
Expand
Absolutely agree with this even ****************ing 6 lads  could drag that ting down ,I did it with much bigger trees alone no winch just pulleys just 4 pulleys  !
  On 22/03/2025 at 19:11, Ledburyjosh said:
That's not a good idea to be fuxking about with blocking a big tree down at head height...
Expand
is there a difference between a good idea and a sensible one?
maybe head height is OTT, but providing you can get it off the stump without trapping your saw then progressively cutting the butt higher off the ground, even to waist height allows the whole weight of the tree to work in your favour, of course it can drop unexpectedly while you're cutting, my ways aren't intended for professional use, only for have a go sole traders
Basically impossible to tell from photos or persons descriptions.
Nonetheless - it's not complicated. There are two options.
1 - Mega access platform with sufficient reach to work from very top of hung up tree and suitable outreach to be safe of anything falling during dismantle process.
2 - Forestry style, mega winch on something powerful and mega heavy and pull that bastard down.
Expand
without being there and knowing all the background and full kit list... is that big blue jobby on the right of the video big enough and powerful enough? (all good from an armchair of course)
Expand
My thoughts exactly as well, been reading every comment on this issue and TBH some of the comments are yet just another accident waiting to happen,, knowing the right cuts, winching experience and experience in dealing with trees in this situation all go a long way,, people on here saying do this do that as they have probably done it once and got away with it ?. one smart arse i worked with a few times knew every thing about tree work and you couldnt tell him any thing at all as Collin was one of them that had swallowed the map and shit the dictionary, hence poor Collin been in a wheel chair now for several yrs as he got pinned against a wall taking a big Willow down on a council job, There was a HSE investigation and Collin only had CS30/31 and the relevant climbing tickets, what the full out come was i not to sure but will make a phone call or 2 tomorrow,,
Expand
The big blue jobby is well man enough for the job,,
Read more
