Was using my Jensen 540 today and a few times over the course of a few hours the engine would bog down and it would chuck out white smoke. I’d drop the revs to stop it stalling give it 30 seconds to clear and then would be fine again. Only seemed to happen while tracking the machine around. While chipping it didn’t have any problems. Also ran the machine yesterday and it didn’t do it once. Its literally just had a full service and the tank flushed. Prior to me picking it up 2 days ago it had been sat in a dealers yard for 6 months not doing anything as the control box had failed. I bought it and had it dropped at TH whites who did the control box plus the full service and probably only ran for an hour or so there. Does anyone have any ideas of where I should start looking?
cheers all
I have had exactly the same problem twice with my Jensen A540 turntable with the same Kubota engine. Obviously not when tracking as it is on wheels, but when under load chipping. The cause was the inline fuel filter between the fuel tank and the cartridge filter being block with crap/debris etc. Easy fix, replace the inline filter, and I carry a spare one with the machine. Usually no need to manually bleed the system, just remember to open the vent/breather knob on the injector pump.
13 hours ago, tim361 said:
TH white changed it twice, I’ll try again and see if that cures it. Thank you.
If it’s been changed twice with little use it's probably not that. Tracking it about must make something move, check all jubilee clips would be my first check.
I'm going either water in the diesel fuel or possibly a coolant leak under heavy load, if it's been sat in the yard for months frost damage maybe as white smoke indicates moisture.
Heavy load is normally black or grey unless it's Baltic.
But I would be tempted considering the work on the fuel system to soapy water spray to make sure everything is nipped up tight and no leaking or split hoses sucking up air.
2 hours ago, Con said:
Another vote for water in the fuel. This ties in with the fact it does it when moving, sloshing in tank.
Didn’t think about this, thanks for pointing it out. Doesn’t seem to be using any coolant but going to keep an eye on it this week. They did clean the machine off before I collected it so might be that water managed to get into the machine that way. I’ll see how it goes over the next few days and report back.
Thanks for your help all.
Is there no low drain on it anywhere? Water catchment bowl etc... diesel will sit on top of water....
If you can try crack a drain and see if diesel or water comes out first...
If the Kubota engine is anything like the forklift ones, the fuel filter is just a tiny type without a water drain.
Probably best to just keep going until the tanks empty as it'll recirculate or dump the lot and change filter think mine was like £7 from a car spares shop as they're the same as those on Hyundai.
